Hi y'all,
I had that question regarding the massive updates I should plan for all my devices, according to that vulnerability...
If I do that update on my devices, are they gonna lose the Remote Monitoring licence the clients already bought ?
Thnx
Solved! Go to Solution.
Installed option keys are not affected by software upgrades, any that are installed will be retained throughout the upgrade process. The only exception is if a change has been made specifically to any option key, but such changes will be documented in the software release notes.
