10-23-2014 12:48 PM - edited 03-18-2019 03:34 AM
I have a Edge 95 MXP and it call's itself all the time.. the call is a SIP call from 100@it's IP address and is a 64K call. I have not power the unit off because it is up in the ceiling. The unit is also registered as a 3rd party endpoint in Call Manager 10.5....... The unit can make calls in and out to our other video units fine. I have had to set the unit to Auto Answer so it does not constantly ring.
Solved! Go to Solution.
10-23-2014 01:42 PM
Usually it's because your getting scanned by applications such as SIPVicous trying detect possibilities for exploiting PSTN trunks over SIP UDP.
This is typically mitigated by closing the firewall ports for the endpoint or making some changes to it's configuration. On a C/EX/SX/MX series codec running TC software that's easy, however I don't know the equivalent commands (if there are any) for an MXP codec. Though you should be able to block the scans that cause this by closing UDP port 5060 if the codec is open in your firewall. If it's going through a call control server such as a VCS you could disable UDP, I don't know about CUCM.
This has been asked many times over, doing a search of the forums for "100@" found the following results, though they all have to do with either a C Series codec or VCS, but it's all the same issue. The device is publicly reachable via the internet, it's just a matter of either closing down or adjusting the configuration of the endpoint and/or the call control server.
lot-calls-numbers-100-and-101-looks-self-calls
10-23-2014 03:30 PM
Here's another one in addition to the ones mentioned by Patrick, this is also an Edge 95MXP: https://supportforums.cisco.com/discussion/12305561/vcs-expressway-intermittently-calls-internet-based-system
Simplest way, but might not be workable for you since you're using a CUCM; turn off SIP on the system.
If you have a VCS as well as the CUCM then all is good as you can register it with the VCS and create a SIP trunk between the CUCM and VCS, and the VCS will take care of the SIP/H.323 interworking.
I'm going to assume your Edge 95MXP is on a public IP address, so another alternative would be to NAT it.
/jens
Please rate replies and mark question(s) as "answered" if applicable.
10-23-2014 01:42 PM
10-23-2014 03:30 PM
/jens
10-24-2014 12:52 PM
Well thanks to Everyone...... It was a Nat call from the outside...... We applied a ACL in the firewall to block the connection!!!
Thanks for pointing me in the right direction!!!!!!
10-24-2014 12:56 PM
Glad to help. Keep any eye on it, and if it appears to still not be resolved, let us know and we can go from there.
Don't forget to mark questions as answered so others that have the same issue can find helpful posts.
