Beginner
Ata point-to-point with another ATA
Hi I want to configure two ATAs back to back without using call manager. Where can I find information to do this?
Thanks and regards.
1 REPLY
Highlighted
Collaborator
Re: Ata point-to-point with another ATA
Mauricio,
Here is a document that can help you configure ATAs to use H323:
http://www.cisco.com/en/US/docs/voice_ip_comm/cata/186_188/2_15/english/administration/guide/h323/h3288CH4.html#wpxref10281
You can make calls from one Cisco ATA to another Cisco ATA in an H.323 network that does not contain an H.323 gatekeeper.
For one Cisco ATA to access a specific FXS port on another Cisco ATA, you use an IP dialing procedure. The Cisco ATA originating the call must have the following information about the destination Cisco ATA:
•E.164 phone number of the destination FXS port
•IP address of the destination Cisco ATA
To enable the IP dialing procedure, you need to set the IPDialPlan parameter to 1 to instruct the Cisco ATA to look for the destination IP address in the dialed digits.
Example
Cisco ATA X is going to initiate a call to Cisco ATA Y (with the following pertinent information):
•IP address of Cisco ATA Y-192.168.2.112.
•E.164 phone number for the Phone 1 port of Cisco ATA Y-1:5556666
•E.164 phone number for the Phone 2 port of Cisco ATA Y-2:5558888
To call the Phone 1 port on Cisco ATA Y, you would dial 5556666**192*168*2*112#.
To call the Phone 2 port on Cisco ATA Y, you would dial 5558888**192*168*2*112#.
Please rate helpful posts.
Dave
Ask the Expert- Webex Hybrid Services Solutions
