Audio in Quad Cam Speakers
steven.gauthier
Beginner
Beginner
I can't seem to find the right setting to have audio through the quad cam speakers. I have a codec plus, HDMI input 1 is used for the camera, and from what I read, audio in supposed to go to the camera through that same HDMI connection, Is there a setting I am missing to make this work?
Thank you
1 ACCEPTED SOLUTION
Ashish Patel
Some things to check
Check your hdmi cables are good and the right ones from Cisco and are connected correctly to codec plus and from codec to camera
Make sure the distances from codec to camera arent in several meters
Place an inbound call and check speaker is working on inbound call and content
Sometimes swap the ends around
Check volume on touch panel/device - I’m sure you have done that.
Response Signature
7 REPLIES 7
steven.gauthier
Beginner
Beginner
Looks like it's not stable. I went back to the room, and now it's working... Anybody had that kind of issue?
No, Never faced such issues.
Response Signature
I had that problem. I had the quad camera set to shutdown with the monitors after the customer was finished using the system, and sometimes when it restarted it received the audio signal, and sometimes it did not. I disassociated the camera from the automated power shut down and left it "always on" and I never had the problem again.
This is a setting in the codec?
Where can I find it?
No, not a setting in the codec. It was being shutdown automatically by my system's controller. I moved the power supply to a different outlet not associated with the system's controller.
Ashish Patel
Response Signature
Ok will do,
The cable is maybe 20-25 feet, but I never lost the image
THanks
