Is there a step by step guide for setting up Audio Only programs in the Content Server for IPTV? I am trying to stream audio conferences. I would much appreciate any help on this
You can play Audio only program in the same way as you are doing with normal program(Audio & Video). IP/TV send the audio & video data on different ports.
So you can make Audio only Live capture program in IP/TV CM as you are doing for normal programs, just uncheck the Play Video option in program creation page in CM.
