369
Explorer
B2B call using SX20 from Internet to an Enterprise that have Expressway-E
There are two independant company that wish to make Videoconference.
The first, companyA, has only a SX20 (H323 direct call like using Polycom hdx or realgroup), and have internet connexion.
The second, companyB, have a full UC with Expressway-E&C + CUCM + TPS + conductor + RMS licenses.
We want that the companyA make call to a CMR on the CompanyB.
How to do, is there any document that can help.
regards,
Antra
2 ACCEPTED SOLUTIONS
Participant
If the SRV records haven't
If the SRV records haven't been set up yet for a domain pointing to the Expressway E or the calling endpoint doesn't have a DNS server available for domain resolution, you may be able to use the IP address of the Expressway E instead of the domain, e.g. alias@ExpE_ipaddress.
In addition to Joe's comment,
In addition to Joe's comment, If external endpoints dial alias@Experssway_IP, a transform will need to be used on the Expressway-E to convert the IP into your SIP domain.
Configuration > Dial plan > Transforms
  • Pattern type: Suffix
  • Pattern string: %ip%
  • Pattern behavior: Replace
  • Replace string: (your SIP domain)
%ip% will match any IPv4 address configured on the server without needing to specify a specific IP address, it will match all.
3 REPLIES 3
All Cisco endpoints, and most
All Cisco endpoints, and most other manufacture's endpoints these days can or should be able to make URI calls using the format "alias@domain", refer to Appendix 2 of the Expressway Basic Configuration Deployment Guide (X8.9) on required DNS SRV records for B2B calls.
I assume you're CUCM and Expressway-C/E is configured correct, but just in case refer to the Expressway and CUCM via SIP Trunk Deployment Guide (CUCM 8,9,10,11 and X8.8).
Participant
Content for Community-Ad
August's Community Spotlight Awards
