Highlighted
Beginner
BFCP through CUBE
Hi!
Is it possible to pass BFCP/UDP thru IOS CUBE (not the SP Edition)?
We have following setup:
CTSendpoint(1.8)>---------<UCM(8.6.2)>-----<SIP trunk>-------<CUBE 2821/15.1(4)>-----Zone------<VCS X5.1>-----------------<TP8710 (2.2)>
        |-----other SIP video endpoints
All standard video content is passed thru normally, but how about BFCP and presentation content? I know that SBC @ ASR1000 has support for that, but is there way to do same with IOS based cube???
/Mikko
Everyone's tags (5)
2 REPLIES 2
Highlighted
Engager
Re: BFCP through CUBE
Hi Mikko!
For now I would assume not, as I see the CUBE like a MTP / RSVP / TRP which is ruled out:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/8_6_1/ccmsys/a08video.html#wp1154149
I would assume that more is coming in the future.
You should also consider about upgrading your VCS to X7.x.
With an VCS-E instead of the CUBE I could picture you deployment would work
Maybe Andreas has some more info.
Beginner
Hi Martin.
Thanks for info - it looks like that given link describes case I'm falling into
I need to think about VCS-E, although in my case, it is not fastest solution...
/Mikko
