Showing results forĀ
Search instead forĀ
Did you mean:Ā
C series audio call
Binesh K
Hi All,
We have one c series endpoint with ISDN link. How can I dial a audio call from C -series endpoint. Currently we are able place video calls to other video endpoints, but calls to telephones/mobiles  were not going.
Please guide me is there any settings to be changed to initiate audio call or it will be automatically negotiated.
Thanks.
3 Accepted Solutions
This is snapshot on TC6.2.0beta3.
Hi Binesh,
It is possible from remote control also .
Use 4th softkey to select callrate .
Kind regards,
Dharmmesh
6 Replies 6
Marius Nedregaard
Hi Binesh.
To call audio only calls, you will have to set the bandwidth for the call to "Audio" .
This can be done on the on screen display menu, on the touch panel or even if you are trying to call from the http interface.
Hope this helped.
Marius
Hi Marius,
Could you please add screen shot/ picture selecting "audio" option. I couldn't find the same on OSD / web interface.
Thanks.
//Marius
HI Marius,
Thank you. Got it. we are able to place call through web interface.
But through remote control , is this setting is available. please confirm
Thanks.
Hi Binesh,
Kind regards,
Dharmmesh
