Cisco Community Designated VIP Class of 2020
483
Highlighted
Beginner
C series codec does not switch to second camera
Hello!
I'm connected a second camera and microphone to a codec, and configured second video input.
Also I set up microphone inputs with correct camera ID's expecting codec to switch on a second camera voice activated by second mic.
But this does not work, second camera input can be selected only manually.
Is it possible at all? Thanks.
Everyone's tags (4)
3 REPLIES 3
Re: C series codec does not switch to second camera
As far as I know this is not supported on the codec. Is there anything in the documentation about this I have missed?
/ Magnus
Beginner
I digged into doc, and also find nothing.
Then what this config is suitable to? I mean VideoAssociation option. What should it do?
Enthusiast
This is not supported yet. Video Association is meant for a different purpose, if you check the administrative guide, you should find this :
Audio Input HDMI [2] VideoAssociation MuteOnInactiveVideo
Enable association of a video source to an HDMI audio input.
Requires user role: ADMIN
Value space:
On: A video source is associated, and the audio will be muted if the associated video source is
not displayed.
Off: No video source is associated.
Example: Audio Input HDMI 2 VideoAssociation MuteOnInactiveVideo: Off
Hence, this just means that if you do not have associated a video source to an audio, the audio would be automatically muted if the video is not displayed.
Hope this answers your question.
Mubashshir Akhtar
Thanks Mubashshir Akhtar
Content for Community-Ad
FusionCharts will render here
