14631
C20 Microphone extension cable Max lenght
Good day
I would like to know if it will be possible to extend the standard C20 microphone cable past 15m...
Thanks!
1 ACCEPTED SOLUTION
Hey Martin
We can use extension for mics for C20. Its even listed in parts and components guide:
CTS-QSC20-MIC=
Performance Mic 20 - 7.5m cable attached
CAB-MIC20-EXT=
Extension Cable 10m, for CTS-QSC20-MIC, 3.5mm F to 3.5mm M
So we can safely say that you can use microphone with 2 extension = 37,5 meters, just over 90 ft.
Rafal
4 REPLIES 4
Rafal Szeremeta
Hello Chris
Microphone cable for C series systems can be extent up to 100ft.
Rafal
Hi Rafal!
If I remember it correct the last official statement for the C20/SX20 I heard was:
* no other mics then the original square ones
* no extensions (SX20 also regards the camera)
Hey Martin
CTS-QSC20-MIC=
CAB-MIC20-EXT=
Rafal
Hi there
Thank you very much for the information rszereme!
Create
Recognize Your Peers
Content for Community-Ad
