Highlighted
Beginner
C40 Dual Display problem
Hi all,
Would be very grateful for a solution here.
I want to be able to see the presentation on the second screen regardless of whether I am sending self image or PC to the far end (1st screen is far end).
I have had a good dig around in the advanced config however I have had no luck.
So to put it another way: I have the far end on the left screen, and presentation on the right, but I want to toggle between sending presentation and self view to the far end whilst always retaining the PC image on the right screen.
Any ideas?
Thank you
Ryan
Everyone's tags (3)
1 REPLY 1
Highlighted
Collaborator
Re: C40 Dual Display problem
With NPP option installed on the C40, you will send both your camera and your presentation at the same time, so no need to toggle. If you want to toggle between camera and a second presentation source - whilst sending PC image, then you'll have to toggle the main source inputs - which you can do from both the menu and the on-screen pop-up tabs - but these needs to be configured as well.
/jens
Please rate replies and mark question(s) as "answered" if applicable.
