02-03-2012 02:20 AM - edited 03-17-2019 10:46 PM
Having problems with our TelePresence Intergrator C40. I wasn't present for the change, but another tech changed the IP, GW, etc and rebooted through the web interface. Once it rebooted it never came back up. Connecting to the codec serial port I get the following message:
Couldn't connect to TANDBERG software.
I've attached the full boot sequence. Any ideas of how I can get an OS uploaded or to fix this?
My hands are tied, not getting a response from the vendor, I took over this system which was put in place 3 months ago and I'm unable to get ahold of the people that coordinated the install. The S/N is registered to another support contract not covered under any of my contracts associated with my profile when trying to open a TAC and I'm getting alot of heat to get this thing fixed ASAP.
Thanks for any help!
-Dave
04-13-2012 12:00 AM
I change folder name to:
C:\Program Files\Cisco Systems\Cisco TFTP Server\pkgfile
04-13-2012 12:11 AM
ok, then make sure all the required files are in the folder. you might want to try to re-download the TC software and try again. Assuming your tftp server is set up correctly and the server root directory is pointing to the server.
If still cannot, you might want to consider opening a TAC case for the TAC to assist you maybe over a web-ex session
04-13-2012 12:18 AM
still same problem, - I just download new
s52000tc2_0_1.pkg
pkgextract.elf
u-boot
How we can meet web-ex session?
04-13-2012 12:20 AM
Raised a TAC case with Cisco and any available TAC will be able to advise you on troubleshooting over web-ex
04-13-2012 02:09 AM
Hi again, I uploded software sucessful - Just install SolorWind TFTP server and everything become good. So Thanks for help
06-18-2013 07:02 AM
Hi All,
I was approached by one of the customers to get a link of the document. I see that the link which is pasted here has been removed. Just updating the thread with the latest document that can be used for this method. Please refer to the following link:
https://supportforums.cisco.com/docs/DOC-27345
Please refer to the following link for the whole procedure.
Mubashshir Akhtar
TelePresence Solution Group
09-25-2013 04:09 AM
Hi Mubashshir
I am also need pkgextract.elf and u-boot file
Can you provide access to https://supportforums.cisco.com/docs/DOC-23161
or send these files to pbx1@ukr.net
I received from my C20 next:
ERROR: can't get kernel image!
br Oleksandr
09-25-2013 07:11 PM
sent to your mail.
regards,
09-27-2013 05:05 AM
Hi Teck
I did it. C20 is online again.
Many thanks.
br Oleksandr
12-22-2015 09:47 PM
01-25-2016 02:01 PM
did you received the files or you still need those?
11-18-2013 01:23 PM
Teck,
Can you please send me these instructions? We have another customer with the same c20 problem.
Regads,
Matt
11-18-2013 04:29 PM
08-27-2013 11:26 PM
Hi. I need these files:
pkgextract.elf
u-boot
From where can I download it? Or can you just send me it via e-mail (kamil.tyminski@hotmail.com). The hardware is Codec c90
Thanks in advance
Kamil
03-03-2014 08:02 PM
Can someone tell me where to get the pkgextract.elf and u-boot.ini files?
