02-21-2013 12:12 PM - edited 03-18-2019 12:38 AM
Is there a good doc/ detail on C90 MIC mixer settings? This would be where you want the 8 MICs to mix input during calls from people in the C90 room during TelePresence calls; of course one can set levels, echo cancellation and such, but a little more on suggested settings, whether MICs will mute below a certain level, AGC, etc. Thanks!
02-21-2013 04:16 PM
Untill you get a better answer, did you check out the developer forum, you might find more
integrators and av technicians there:
http://developer.cisco.com/web/telepresence-developer/forum
02-22-2013 06:37 AM
Thanks Martin; I will check it out!
