Explorer
Call a CMR from Expressway
1. I'm trying to call my Meeting Room from Internet, through Expressway-E : What I should do on Exp-E, Exp-C, CUCM. Is there any documents for this? The remote endpoint is a simple H323 device like Polycom or other SIP.
2. I'm trying also to call an externall video through Expressway-E: is it possible or not.
Antra
1 REPLY 1
See the CMR Cloud Enterprise
See the CMR Cloud Enterprise Deployment Guide (WBS31) on how to setup your CUCM and Expressway-C/E to connect into a CMR Cloud meeting.
You should be able to call external endpoints, refer to the Expressway Basic Configuration Deployment Guide (X8.8) on configuring your Expressway-C/E to make calls out via DNS.
Content for Community-Ad
August's Community Spotlight Awards
