01-16-2013 01:44 AM - edited 03-18-2019 12:26 AM
Hi all,
We have implemented SX20 in our customer site and customer has the old tandberg 880 model (software released 2003).
When SX20 call to tandberg 880 I got busy but when tandberg 880 call back to SX20 I got only audio.
Anyone please suggest what parameter I should adjust
Tinnakorn
01-16-2013 03:15 AM
You did not say anything about the kind of deploment and how they dial each other up, nor anything about the
software versions used.
If its a real Tandberg 880 (classic) and not even a 880MXP (I think they were introduced in 2005)
I would replace it with an other SX20, they will not have fun with that system anyhow.
Besides that I think there were different sofware releases on the classic systems suppoting h264 or not.
Check the codec capabilities and try with a call rate <=512kbit.
It can also be a firewall or ALG/Helper issue.
Anyhow, the suggestion is: replace the 880 classic system.
I guess you are also not using your mobile phone from 2003 anymore :-)
01-16-2013 06:26 AM
We just test the direct IP to IP call h323.
SX20 software: TC5.1.3
Tandberg 880(classic): E2.2 PAL
Release Date: 2003-08-29
Codec Version: 384kbps, opt:1
Sorry for the first post, actually I got video when tandberg 880 call sx20 but video quality at tandberg side very bad
sx20 side is not bad but not good, BW between 2 sites is 200Mbps which should enough.
Here is the call status when tandberg 880 call back to SX20
video at tandberg side
Reduce BW call to 512, 256 still got bad quality
call from sx20 to tandberg failed as mention in the first post.
Thank you
01-16-2013 11:01 AM
Hi.
I think this will be hard to troubleshoot, as Martin said this is an really old system.
Not only is it horrible outdated, and EOL - but you also run an really old software revision ( almost 10 years old )
I would recommend you to install the newest E-software as a start, found at
ftp://ftp.tandberg.com/pub/software/endpoints/classic/e-series/880_ip_only/pal/e53/ and then post results here.
//Marius
01-16-2013 01:15 PM
He's not going to be able to upgrade without release keys.
The SX20 will have to be dumbed down quite considerably for this to work properly anyway, we normally bridge old systems when we encounter one, seems to work a bit better, not great, but a bit better than going point-point.
Realistically though, forget about the 880, keep it as a TANDBERG memento and tell the customer to get with the present and invest in another SX20...
/jens
01-16-2013 11:57 AM
Memories... I remember paying more than NOK 4000 (≈ EUR 550) for the Sony Ericsson T610, and then breaking its screen after just a month!
01-16-2013 01:53 PM
