07-03-2018 07:31 PM - edited 03-18-2019 02:13 PM
Guys,
Have setup a clustered Collab-Edge environment, with the Expressway-Cs neighbouring multiple CUCM Clusters.
The Expressway-C's also have Room TP Licenses with registered SIP Endpoints.
From Endpoint A (registered to Expressway1), I can call to CUCM Cluster 1 (v11.0.1) and vice versa. The logs tell me its a non-traversal call type.
From Endpoint A (same as above), I cannot call CUCM Cluster 2 (v9.1.2) and vice versa. The logs are telling me its a traversal call type. I cannot for the life of me figure out why this call is being marked as traversal? And as I do not have any RMS Licenses installed on the Expressway-C's, the call does not go through..
Has anyone experienced this issue? I have a feeling its the versioning on CUCM that is throwing the licenses out of whack.. however I cant find documentation to back this theory.
Any thoughts?
Ben
07-04-2018 08:02 AM
07-04-2018 04:54 PM
Thanks for your reply..
I can assure you there the path is direct, no inter-working or MS interop.. The Expressway is classifying the call as a traversal when only matching a rule for this CUCM neighour. When I use the same rule and select a different CUCM neighour, the call works fine as the type is a non-traversal..
The only difference is the CUCM Cluster versions.. The CUCM version not working is v9.1.2. Versions that are working are 10.5.2 and 11.0.1. The expressway version is x8.10.4.
I can only 'assume' that the Expressway is not identifying the old CUCM correctly.. hence seeing is a a third-party gatekeeper.. therefore wanting a traversal license to send/receive calls from this neighour.. But I cant find any doco on this..
Have attached the logs for you mate.
8803@... is the VC endpoint registered to Expressway-C
869@.. is the CUCM endpoint
Ben
07-05-2018 10:46 AM
07-05-2018 01:39 PM
07-05-2018 12:24 PM
The issue you are experiencing on calls between EXP-C x8.10.4 and CUCM version 9.1.2 is due to the bug CSCvi82794.
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvi82794/
It looks like an operability issue with CUCM 9.x and Expressway. We are still looking into this issue. As a workaround, you can set the Neighbor zone profile for the CUCM 9.x to “Default” and go to Configuration > Call Routing > and ensure that call signaling optimization is set to ON.
Shashank
07-05-2018 01:42 PM
Hi Shashank..
This seems likely.. I have applied the workaround to no avail though mate.. Still consumes a traversal license..
I found out yesterday the actual version of CUCM is 9.1.12 not 9.1.2.
I also have a TAC case opened with Parteek working on this.. SR 684756698
07-16-2018 06:08 PM
Hi Shashank,
Looks like it is BugID:CSCvi82794.. has been updated last week.. no workaround as yet. Looks like the CUCM will need to be bumped up..
Ben
