02-11-2013 01:38 PM - edited 03-18-2019 12:34 AM
Hi Folks
We have a customer that has purchased a SX20 and also a Audio Science Ceiling Mic. I had a 3.5 "4 Pin Cable" made up to extend from the Codec, But when I plug in the Audio Science ceiling Mic , I cannot be heard.
Has anyone com across this issue ?
I have checked the pin outs ...all ok.
As a thought ...Are they compatible ?
Rob
06-06-2013 05:10 AM
Hi Rob
Maybe the following could work - I haven´t tested this, but maybe you could:
notes:
The disadvantage will be, that you´re not able to control the volume and that you will make the cable by your own. There may be better ways to solve this:
Tino
06-25-2013 07:22 AM
We used the schematic above, inserted 2 capacitors, and verified this works great! My users are very happy. Below you will see our notes/comments. We really needed this to work, so I cut the phono plug off of the supplied SX20 microphone to make this cable.
06-25-2013 07:30 AM
good to hear. thanks for testing.
I´ve summarized all
http://conftech.blogspot.co.at/2013/06/connect-third-party-microphone-to-cisco.html
11-12-2014 04:40 AM
I had to make several more of these connectors, so I sourced the 4-conductor, 3.5mm plug from digikey: PN- CP-354S-ND. Only $7.30 ea.
11-12-2014 08:32 PM
There's lots of places you can get them, and $7.30 is pretty expensive. You can get just the 4 pole 3.5mm jack for US$2.35 from Element14: PSG01490
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Please remember to mark helpful responses and to set your question as answered if appropriate.
11-24-2014 02:50 AM
If you prefer to get it ready made, you could also use the revolabs cable together with two adapters:
Vendor | Part # | description |
Revolabs | 07-35MBTO35M4-01 | 3.5mm Balanced Male Connector to 3.5mm Male 4 Conductor |
Neutrik | NA3FJ | Neutrik NA3FJ Stereo Jack to XLR-female |
Hosa | MHE-310 | Stereo Mini Female to Stereo 1/4" Male |
You can get it from www.bhphotovideo.com or other sources.
The last two adapters can be replaced by other brands if needed.
I have also found a ready-made one here, but it seems, that it has a XLR-male instead of a XLR-female - i have send a message to them regarding this.
In anyway, you´ll need an external Phantom Power supply, if the Mic needs power.
11-27-2014 12:50 AM
The guys from AVShop.ca confirmed, that their ready-made microphone cable for SX20 comes with a XLR-female instead of the XLR-male like shown on the photo.
They also confirmed, that they can ship the cable globally and they do also have a suitable phantom power supply if needed.
You can order it here.
thanks
Tino
