Cisco Codec Pro Visco camera control
HarryChua
We used to use Visca to control Panasonic PTZ cameras like the HE-130 from the SX80. With the new Codec Pro, is there a way to continue to use Visca control or using IP?
Wayne DeNardi
The codec pro doesn't have any serial connectivity, so cannot control a Visca camera directly.  You would need to add some third party equipment in between.  (Ie, you could set up buttons for camera control on the Touch10 UI, then have an external device monitoring for these presses via the xfeedback or a macro, then trigger its own serial connection command to the connected Visca camera, or even a custom IP control command).
If you use one of the Cisco Cameras (ie Precision 60), then camera control is done by the codec over the Ethernet connection using the endpoint API.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
Do we have a list of which Sony cameras with Visca over IP are supported with the Codec Pro?
Harry Chua
The Release Notes say the Sony SRG-120DH and EVI-120DH are the two that are officially supported for pairing and basic usage with pan tilt and zoom.
Wayne
I just setup a Sony SRG-120DH on a RK Plus. Very limited, but I am able to move the camera around. Zoom was not working but i only just connected it.
