12-14-2018 05:42 AM - edited 03-18-2019 02:31 PM
Hey Guys,
A newbie question : what's the best practice about registering codecs on a VCS :
SIP or H323 ?
Do you think its good to registering both ?
Thanks for you replies
Solved! Go to Solution.
12-14-2018 08:07 PM
It really depends on your requirements.
Cisco codecs support both and you can register through SIP and H323 at same time and there is no issues in doing so.
But I think using SIP is better idea as everything is moving towards SIP and its easy to troubleshoot as well.
Please rate if it is helpful.
12-14-2018 08:07 PM
