02-14-2013 01:11 AM - edited 03-18-2019 12:35 AM
Hi!
We have an installation with
VCS 7.2, TMS 13.2.2. and a bunch of jabber video users. TMSPE is using for provisioning and etc, TMS and VCS are configured to import users from AD:
VCS in in AD domain, AD srvices is configured, Default Zone is configured as Check Credentials, Default SubZone is configured treat as authenticated. Movi users are provisioned and imported in TMS from AD - i can see them in phonebook management, Movi version is 4.5, in configuration template phonebook@asb.by(asb.by=local sip domain) is configred. The group with movi users has access and permission to search the phonebbok. The problem is that when a movi user try to search for another user - the search attempt fails - it gets nothing. However the contact he's searcing is logged in with movi and appeared in provisioned devices. For example the EX60 ep is provisioned with phonebook - it has a full ist of users (contacts) imported from AD and created locallly.
Solved! Go to Solution.
02-14-2013 02:19 AM
Can you check the TMSPE diagnostics in TMS and see if the phonebook button are red.
Also check the Phonebook source activity status in TMS and see if you see any errors.
Make sure you perform a full synchronization with the TMS from the VCS (provisioning tab, click "Perform a full synch now")
Also on the VCS you can actually check if the phonebook entries exists in the VCS and that the users have access to them.
Status --> Application --> TMSPE --> phonebooks
Let me know if you see any errors relating to the phonebooks in TMS.
/Magnus
02-14-2013 02:19 AM
/Magnus
02-14-2013 03:34 AM
Hi, thank you very much for your answer.
I've forgotten that by default vcs performs sync with phonebook every 12 hours.
Seems like everything is ok now - i can search for users in movi. I'll test a bit longer and let you know about the results
the problem is resolved.
