In Single-Split Deployment, TURN server and Webbridge server are co-located on Edge server. By default, they both listen to same port 443. In the document, it says either use two interfaces or change the port TURN server listens to, i.e. 447.
In my DMZ setup, I only have one subnet. So the only option for me is to change the port.
In CMS API reference guide, it is not very clear. In section 10.7.2, it says to use the tcpPortNumberOverride to override the port.
But when I connect poster to edge server, GET https://<Edge FQDN>:445/api/v1/turnServers, it responds with 200 OK <turnServers total="0">.
Anyone can show me how it is done? Thanks.
