Cisco MX700 not saving system name or ntp
Dallas Brown
We have a new MX700 telepresence system. When I set the system name under Configuration>System Configuration>System Unit  and hit the save button the name will update as expect on the touch pad. If I reboot the system that setting is lost without fail. Same with the ntp server ip.  Anyone else have this issue?
The issue is a problem because the system name is what the unit uses when it registers with DHCP, which in turn means the DNS name keeps changing back to "localhost" instead of the name I choose.
Code is
Current version
TC7.3.0.8cb420c
Dallas
When you register a TelePresence endpoint to CUCM, configuration of the endpoint comes from CUCM.
Administering Endpoints Running TC7.2 on UCM 10.5.1
See pg 21 for SSH and pg 25 for System Name.  Probably best to go over the entire document to make sure everything is set correctly, just in case.
I didn't see NTP in that guide, but found an older guide where it said to do the following:
Setting a NTP Reference for the endpoints
In UCM Administration > System > NTP Reference
Configure a Phone NTP Reference for the endpoints.
*The NTP Reference must be in Unicast Mode.
*Assign to Date/Time Group, which in turn is assigned to Device Pool.
5 Replies 5
Dallas Brown
As a workaround to the device not saving these settings threw a reboot, I was able to use a start-up script to reset them every time the device launches.
Configuration>Start-up Scripts
xConfiguration NetworkServices SSH Mode: On
xConfiguration NetworkServices NTP Address: "x.x.x.x"
xConfiguration SystemUnit Name: "my-system-name"
Hello Dallas -
How do you have the MX700 deployed and managed - CUCM, VCS, TMS?
It is registered with a CUCM 10.5 server.
Thanks Patrick, this all worked. Had I just scrolled down the config page I may have saw that for myself........appreciate the reply
