Walkthrough Wednesdays
760
Daniel Isham
Enthusiast
Cisco MXP 6000 Audio Only Streaming
We have a CODEC MXP6000 in which we are trying to stream the call using the stream.sdp technology. We have configured a multicast address and are able to access the streaming page but are getting audio only. We have tried the following:
Stream address of 255.255.255.255
Updating QuickTime on client laptop
Tried using VLC
Tried different streaming ports
Toggled video quality settings
Disabled firewall on computer
There is a proxy in which the browsers are all pointing to. Is there anything else I could try to get the video to stream along with the audio?
1 ACCEPTED SOLUTION
John Regan
Beginner
I have it working using an 1000 MXP.
I have the streaming settings:
Address: 224.0.0.0
Address Port: 22232
Video Rate(kbps) 320
Video Quality: Motion
Then I start streaming and in my Firefox browser on my mac enter http://ip.address.of.mxp/stream.sdp
and I get video and audio in my browser (uses quicktime plugin)...
I could not open from Quicktime directly on my Mac for some reason.
4 REPLIES 4
Daniel Isham
Enthusiast
Also we are trying this on the same lan as the CODEC itsself.
John Regan
Beginner
Address: 224.0.0.0
Address Port: 22232
Adding to John,
Another  way is to .
http://ip address of the codec/showstream.ssi
address range should be in multicast range
Addresses in the range
224.0.0.0
to 224.0.0.255
thanks
Ravi kr.
I will try the multicast range that both of you suggested. I was currently using 224.2.0.10. All other settings are identical to John's. Thanks for the tip and I will let you all know the outcome.
Content for Community-Ad
Spotlight Awards 2021
