04-01-2018 10:09 PM - edited 03-18-2019 02:01 PM
Since earlier sx20 support multisite conference internally and after going through the datasheet of spark room kit and plus i'm unable to find that.
Now my customer looks to have video conferecing end points for its 4 sites in a single campus, do i still need to give some sort of on-premises manager or cloud services in this case?
Solved! Go to Solution.
04-02-2018 07:25 AM
Your wording is somewhat confusing, but I believe you are asking if you can order the multisite option on the SRK as you could on the SX20, is that correct?
You can, but for some reason it's a separate order on these newer systems from Cisco rather than an option like it used to be. Check the ordering information in the datasheet, it's in there:
You need to use the L-ROOM-PAK as the top level part number and then L-KIT-MS
04-02-2018 07:25 AM
