10-31-2017 12:24 PM - edited 03-18-2019 01:35 PM
Does TMS 15.5 support Cisco Spark Room Kit running CE 9.1.3 or do we need to upgrade TMS to 15.6?
Thanks for your feedback.
Amrit
Solved! Go to Solution.
10-31-2017 01:12 PM
10-31-2017 01:12 PM
10-31-2017 04:56 PM
Thanks Patrick for your quick reply.
Best Regards,
Amrit
12-11-2018 04:01 AM
Based on my experience you need at least TMS 15.6.1 to be able to upgrade the Room Kit Plus units correctly. It requires to be upgraded using the .loads file, which is not supported in TMS 15.5. Upgrading with the .pkg file results in the camera not being upgraded correctly.
