03-18-2014 10:40 PM - edited 03-18-2019 02:45 AM
hi,
i am trying to call from codec cisco sx20 to polycom rmx 1500. but call does not complete
polycom rmx ip address 172.26.160.5
if i dial 172.26.160.5 call does not hit and if i dial 172.26.160.5##2002 i.e meeting room in this case also does not work
for refernce logs are attached.
kindly share your experience
regards
rajat
Solved! Go to Solution.
03-20-2014 08:03 PM
Check the software versions on both endpoints to make sure they're current and including as many interoperatbility fixes as possible (ie, TC7.0.2 on the SX20, V8.2 on the RMX).
There seems to be a capset issue between the two devices - the log file you attached before indicates this:
Mar 18 15:54:06.990 a8 appl[1423]: 270.61 H323Call I: h323_call::sendOutgoingModesToStack(p=12): Modes sent to stack [seq=1]: audio: G.722, video: vid-off, duo: vid-off, data: H.224-HDLC]
Where it is negotiating audio at G.722 and there is no video available.
You could also try a capset filter on the SX20 (or whatever the Polycom equivalent is on the RMX end, if possible) to try to force the devices to talk (or not talk) a specific protocol.
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Please remember to mark helpful responses and to set your question as answered if appropriate.
03-18-2014 11:09 PM
The Cisco codecs don't support the polycom "ipaddress##alias" format - that's a non-standards based way of doing thing that is peculiar to Polycom devices. Have you tried using the "alias@ipaddress" format (ie 2002@172.26.160.5)?
Wayne
03-19-2014 01:24 AM
hi,
i tried 2002@172.26.160.5 to call rmx. the call is not hitting still in rmx. any other clue to resolve
03-20-2014 01:59 AM
i have tried 2002@172.26.160.5 while selecting protocol SIP. the call connect for a moment and it auto disconnect. can any body suggest to resolve this issue.
regards
rajat
03-20-2014 08:03 PM
Wayne
03-25-2014 10:12 PM
after upgrading software of sx20 it is working
05-03-2016 05:12 AM
hi Wayne,
i have SX10 standalone, is it possible for SX10 to call polycom RMX?
