03-28-2013 01:57 PM - edited 03-18-2019 12:51 AM
I was wondering if anyone has come across this issue with the SX20 QuickSet:
- SX20 goes to standby and CEC works normally, so that the screen goes in standby
- The SX20 is restarted from the GUI
- The SX20 restarts and the CEC functionality renders non operational; the codec does not wake up the screen anymore, it stays in standby although the codec is active - even more, this appears so only on HMDI output 1, HDMI output 2 works well and as expected
Software version is the newest TC6.0.1
Cheers,
Mihail
04-15-2013 08:31 AM
as discussed a while back, development thinks the issue could be related to the absence of "hotplug" from the monitor. To prove this, were you able to repeat the test and gather the following outputs at the linux prompt :
v4l2-ctl -d 2 --log-status
For comparison do also HDMI-2
v4l2-ctl -d 3 --log-status
With the Hot Plug Detect (HPD) signal, the sink indicates its presence to the source device. Hot plug detect is the
first step in source device recognizing a sink has been connected. The sink can toggle the hot plug detect signal
to reset the HDMI connection.
04-23-2013 07:13 AM
Hello Danny,
Here is the output.
What I did first is repeat the exercise, meaning, put the codec in standby, reset via GUI, and then get the output from the commands.
As you can see, the codec woke up the LCD screen on HDMI 2 , but the one on HMDI 1 is still in standby.
[exampe-1-example-com:~] $ v4l2-ctl -d 2 --log-status
Status Log:
asterix-v4l2: ================= START STATUS =================
asterix-v4l2: Version: 0.1.0
asterix-v4l2: Card: Asterix (Cisco SX20)
asterix-v4l2: hdmi-tx: +5v on
ad9389b 4-0039: chip revision 2
ad9389b 4-0039: power off
ad9389b 4-0039: detected hotplug, no Rx Sense, no EDID (0 block(s))
ad9389b 4-0039: ad9389b: no encryption
ad9389b 4-0039: state: in reset, error: no error, detect count: 0, msk/irq: c4/00
ad9389b 4-0039: ad9389b: RGB quantization: full range
ad9389b 4-0039: ad9389b: manual gear 1
ad9389b 4-0039: timings: 1280x720p60 (1650x750). Pix freq. = 74250000 Hz. Polarities = 0x3
asterix-v4l2: ================== END STATUS ==================
[example-1-example-com:~] $ v4l2-ctl -d 3 --log-status
Status Log:
tx_ti: timings: 1920x1080
tx_ti: detected hotplug, detected Rx Sense, found EDID (2 blocks(s))
tx_ti: HDMI output enabled
tx_ti: Configured timings: 1920x1080p60 (2200x1125)
tx_ti: horizontal fp = 88, +sync = 44, bp = 148
tx_ti: vertical fp = 4, +sync = 5, bp = 36
tx_ti: pixelclock: 148500000, flags: 0x2, standards: 0x3
tx_ti: RGB quantization: full range
tx_ti: cec: enabled addr 4
10-17-2013 11:18 PM
Any solution for above problem?
10-18-2013 02:26 AM
I missed the reply from April 23rd somehow.
Updated the ddts with that data hoping engineering can shed more light on this.
Danny.
