Highlighted
Beginner
Re: Cisco SX80 removing 'No camera connected' warning from OSD
Would also like to add that this is the correct answer to this problem, with no extra screen workaround required!
Highlighted
Rising star
You can't, only the original poster can choose the correct answer. This thread is three years old, the answer then was the correct answer then.
Highlighted
Beginner
That did it !
Thank you.
Log in to the codec.
(you need the IP address, username / password)
Go to:
Setup > Configuration > Peripherals > (in the “Profile” area, set “Cameras” to 0.
Press “Save” on the top right of the screen.
Message went away.
