10-28-2021 11:13 AM
We have several Cisco TelePresence SX80 units we use to interact between schools in different cities, they are connected to Epson BrightLink Pro 1470Ui touch screen projectors. Is there any way we can interact between touch screens through the Cisco Codec? The Projector has this ability, but only in white board mode and only on the same WLAN.
Solved! Go to Solution.
10-28-2021 07:51 PM
As the SX80 is End of Sale, and past it's End of SW Maintenance date - there will not be any further development of that platform. So this is probably not easy to do on the old SX80 platform - if you were using a newer codec that could be registered to the Webex Cloud, and that supported the Whiteboarding functionality, then it would be possible to collaborate on virtual whiteboards from different locations. The Webex Board Pro is a good example of one of the newer devices which can do this.
Please remember to mark helpful responses and to set your question as answered if appropriate.
10-28-2021 07:51 PM
