03-07-2017 01:25 PM - edited 03-18-2019 12:51 PM
Since the Conf control center in TMS 15.3 has such a problem with Java on every browser I can imagine trying to run it on, is there an alternative that can accomplish the same basic thing? Something standalone like the real-time monitoring tool for UCS? Something else completely?
One of these days I truly hope Cisco gets fully away from Java for management tools. Every random update causes havoc with asdm, tms, vsom, etc...
Solved! Go to Solution.
03-08-2017 03:40 PM
Since CCC doesn't support Cisco Meeting Server, there is a solution coming for that, but I'm not sure if it's a total replacement of CCC for all conference bridges (ie: MCU, TelePresence Server, Conductor). You should reach out to your Account Manager, they should be able to provide more information regarding the solution and it's capabilities.
And I agree, Java is a pain, it has been for years.
03-08-2017 03:40 PM
03-15-2017 06:48 PM
Update on my last reply, the conference monitoring solution that is being worked on is currently only for Meeting Server, since CCC doesn't support CMS. CCC is still used to support the other conference bridges types: TelePresence Server, MCU, Conductor.
03-16-2017 02:33 AM
Any info as to when it will be available?
03-16-2017 05:29 AM
No idea, if I had to guess, sometime in the coming months. Your Account Manager should be able to tell you though.
05-18-2017 06:02 AM
Is there a solution for CCC yet? I just upgraded TMS to 15.5 and still doesn't work. What is everyone else using to monitor live calls on CMS & TMS?
05-18-2017 07:46 AM
Monitoring solution for CMS hasn't been released yet, most likely sometime over the summer. Right now you have to rely on looking at the conference on the List Conferences page within TMS and directly monitor the calls from within CMS. If you're looking for a third-party solution, you can take a look at Acano Manager.
05-18-2017 12:59 PM
Thanks for the reply Patrick. As mentioned we upgraded TMS to 15.5 and it seems that the CCC function works on WIndows 10 PC's but not on W7. Both PC's are running Java8(131) and using IE11 on both as well.
here's the error:
05-18-2017 01:44 PM
What version of Java do you have installed, 32 or 64-bit?
For example, if you've installed 32-bit Java and you're using a 64-bit browser, Java will not be detected.
05-22-2017 02:13 PM
Thanks Patrick! Java was indeed the culprit.
03-16-2017 05:34 AM
So in other words, No.
Dang. Thanks for the other info.
