Walkthrough Wednesdays
1739
cjoseph23
Beginner
Cisco Touch 8 - Lock Administrator Settings
We have 10 or so MX200/300s and we are finding end users who are accessing the administrator settings on the touch panel and making changes to them.  I think some people are just curious and going through the menu option.
Is there a way to password protect the administrator settings on the touchpanel?
We are running TC4.2 on the endpoints.
Cyril
1 ACCEPTED SOLUTION
amehla
Hi Cyril,
you can restrict the admin settings access to endusers by enabling the menu password.
You need to use a command line interface to set the Administrator Settings menu password; you neither can use
the Touch controller nor the web interface.
Setting the Administrator Settings menu password
1. Connect to the system through the network or the serial data port, using a command line interface (SSH or Telnet).
2. Type the following command:
xCommand SystemUnit MenuPassword Set Password:
The password format is a string with 0–255 characters.
2 REPLIES 2
amehla
Hi Cyril,
Thanks for the info.  I made the above changes and I was able to lock down the administrator setting on the touch panel.
Cyril
Content for Community-Ad
Spotlight Awards 2021
