Community Helping Community
1222
Cisco VCS and Lync 2013 integration
I have installed a demo setup. I have integrated the VCS with the Lync 2013. Everything works as expected. The video is very good. But I see some issues which the customers might consider as a problem. Can you please advise a solution or a workaround about the below issues:
     -     I can not see the presence information of the Lync users from the Cisco telepresence endpoint.
     -     I can not search Lync users on the Cisco Teleperesence directory.
     -     I can not add the Cisco Telepresence endpoint into the meeting on the Lync AVMCU.
Tufan
1 REPLY 1
Engager
Please alsways state how your deplotment looks like, like if you use CUCM or only VCS, if TMS is present, ...
If this is critical for you, please do a feature request on that.
Use TMS and generate a phonebook based on AD
Use the Ciscp TPS / MCU and let the lync 2013 clients join there.
Some companies are doing a good job on breaking interoperability. And I do not see that its Cisco here ;-)
Please remember to rate helpful responses and identify helpful or correct answers.
Content for Community-Ad
FusionCharts will render here
