Beginner
Cisco VCS Appliance CE1100 first boot issue
We have and issue with 3 new VCS appliance, after the power on at first boot the system stuck at the level as showed in the PDF attachement and there is no prompt for installation wizard.
Everyone's tags (2)
10 REPLIES 10
Re: Cisco VCS Appliance CE1100 first boot issue
The image taken doesn't show the entire screen, so can't see the last lines of the output.
What happens if you hit Enter?
Beginner
the screen is fixed at this point: IP_table and ip6_table . nothing happens when I press the enter key or CTRL ALT DEL.
Regards.
Everyone's tags (1)
Beginner
Have you solved it? I have the same issue.
Highlighted
Beginner
not yet, I will replace them because they are under warranty.
I couldn't find anything that would help explain what you're seeing.  If it's not booting completely after a while, even after following all steps in the VCS CE1100 Appliance Installation Guide, recommend you contact TAC, it could be a configuration or even a software/hardware issue.
R A Beginner
Beginner
Dear,
Did you solve this issue as I have same ?
Please tell me the action to get it fixed .
Remob
R A Beginner
Beginner
Dears,
I have same issue , did you solve it and how ?
Or that will need RMA ?
Remon
Beginner
I've solved it. We must connect a console cable to set up the bootup wizard. After that we can see the CLI via KVM.
R A Beginner
Beginner
I was connecting Console cable to screen and keyboard , booting stuck as attached screen shot before set up wizard appeared to us.
Please tell me if there's another missing step should I do to get it fixed?
Remon
From X8.9 software release, introduce “Secure Install Wizard” which require to complete the initial setup on the system console.
All accounts on the Expressway/VCS are disabled upon first boot until the installation is complete.
The system is also not accessible over the network interface until the installation has been completed and secured.
New install (including factory reset or reset by IRP on CE1100) CE Appliance stop after “Netfilter Core Team” line print out on KVM console and Expressway (or VCS) application doesn’t boot up.
This caused by accessing wrong console port on CE Appliance.
CE Appliance based on UCS has multiple “console” connection.
Method 1: Console connection back  of server
Method 2: Console connection by using 3 legs KVM connector (connecting KVM port front of UCS)
Method 3:  KVM Console via CICM
Method 4: Serial over LAN (disable on default) control by CIMC
KVM Console connection method 2 and 3 are NOT serial connection to Expressway (or VCS) application.
Only method 1 or 4 connect to Expressway (or VCS) application and allow to run the initial secure installation wizard.
Therefore setting up CE Appliance via KVM console (method 2 or 3), application is waiting administrator input to complete the initial secure installation but won’t see it on console.
Content for Community-Ad
August's Community Spotlight Awards
