01-30-2012 09:57 AM - edited 03-17-2019 10:46 PM
During the last few months I have been working on a tool called SMART. SMART will and can assist you parse and analize Cisco VCS SIP and H323 output traces either collected using netlog or by properly downloading the diagnostics log file from Cisco VCS version 7.x. I hope you find SMART a useful tool.
Overview
SMART is a POWERFUL Output log parser and analyzer
capable of parsing and analyzing single or multiple SIP,
H323 and Q931 logs files from various platforms such as
Cisco Telepresence Video Communication Server, Cisco
Unified Communications Manager, Cisco Telepresence Systems,
Cisco IOS and others. Thus, SMART reduces painful, consuming
and critical log analyzing time for the engineer while providing
accurate parsing as well as reporting.
Features
Installation
SMART requires the following hardware and software in order to properly install and run,
-1 GHz x86 processor
-512 MB of RAM
-512 MB Hard Disk space available
-Microsoft Windows Professional
-Microsoft Windows Vista
-Microsoft Windows 2000
-Microsoft Windows 7
*.NET Framework 3.5 is required.You can download SMART here or by visiting www.telepresencebridge.com/smart
10-08-2012 06:29 AM
Too bad, link and website are down...
Is there anybody who can upload the tool on any download platform?
Thanks a lot!
10-08-2012 06:35 AM
Hi Gabriel
Check your e-mail
/Magnus
10-08-2012 06:36 AM
Thanks a lot Magnus !
You're the king ;-)
10-08-2012 06:36 AM
I have momentarily stop any further develoment on SMART. Although SMART can be still be downloaded by visiting the following link https://www.box.net/shared/ftjb3178xuvgoneyf6qh
You will notice a bit of delay when opening SMART and this is due to SMART trying to connect to it's update server which is currently offline, same for the registration screen. Although eventually SMART will open and run as normal
Thanks and I apologize for the inconvenience.
Cesar Fiestas
10-08-2012 07:13 AM
Thanks Cesar,
Just to know, for the first time users, it looks that we are not able to launch the software because of the registration step: it missed and display a SQL server related error, then no way to go further.
is there a way to "Bypass" taht?
Thanks a lot !!!
10-08-2012 07:16 AM
Gabriel,
Correct, the SQL error is displayed because the update server is offline, hence it cant insert the registration information into the tables/sql srv. Clicking OK should bypass the registration. In order to fully bypass the registration i will have to make changes on the code. Thanks
Cesar Fiestas
10-08-2012 07:38 AM
I tried me too, but it seems that the program exits after showing the error.
Any suggestions?
Paolo
10-08-2012 07:40 AM
Well, since the server is down, the registration process looks like a mandatory step, and the code needs some changes to works.
If you have time Cesar, that will be awsome :-).
Thanks a lot !
10-08-2012 07:41 AM
Guys,
What happens if you guys press any other button than the ok button? thanks
10-08-2012 07:43 AM
I have the same issue....
10-08-2012 07:45 AM
Gotcha!
When the registration process ask first name/last name: just click on the red cross, and it will bypass the reg and switch to the main screen.
Thansk you Cesar.
10-08-2012 07:46 AM
Gabriel,
Thanks for your patience and for giving it a try. I will try to get the update server up this week along with releasing another update to the code.
Cesar Fiestas
10-08-2012 07:51 AM
I only ave a flash on the PC screen. I can't open the application
10-08-2012 07:53 AM
Buisson, when you launch the SMART application, when the software promp you to register==>Click on the whit cross in the red box on the top right to "close" the registration (like if you want to close an explorer on windows).
10-08-2012 07:56 AM
Thank you very much
