07-18-2020 03:50 AM
While trying to generate the 16 digit webex activation code for Cisco webex room kit plus,
I couldn't sign in to settings.webex.com
Please help
07-18-2020 10:12 AM
07-18-2020 10:49 AM
Thank you Jonatan...is subscription is required? And what kind of subscription..? even when I am going to join existing domain is subscription required?
07-18-2020 03:13 PM
Here's the data sheet for device registration: https://www.cisco.com/c/en/us/products/collateral/unified-communications/cisco-collaboration-flex-plan/datasheet-c78-742548.html
Many, but not all, of the current Collaboration Flex Plan annuity subscription offers include this. You should review your current subscription with your Cisco account team or partner to understand what you're entitled to.
08-23-2020 07:04 PM
How to get Register Room Kit if can't login into https://admin.webex.com/login
07-19-2020 08:48 PM
You only need the activation code if you are registering the Room Kit Codec to the Webex Cloud.
If you are going to use it registered to another call control (CUCM, VCS, Expressway, or Standalone) you don't need to use the code at all, and can instead skip the startup wizard completely.
