05-10-2021 06:55 AM
Hi All,
I need to register a Cisco webex romm kit mini with cucm 11.0 in third party device but the status is rejected.
I cannot do the upgrade for cucm now.
any help ?
Solved! Go to Solution.
05-10-2021 07:29 AM
Why do u want to register it as third party. Install device package if it’s not showing. I have CS kit mini running on Cucm11.x.
05-10-2021 08:56 AM
I would recommended to upgrade CUCM to 11.5 on which Webex Room Kit Mini is supported. Even if you get this device registered as third party SIP endpoint, some of the features may not work.
05-10-2021 06:58 AM - edited 05-10-2021 07:02 AM
Check the firmware. Hope you configured the DN for CS kit.
Most probably it could be firmware. You can also try a factory reset.
05-10-2021 07:16 AM
Thank you for your reply,
Just For your information, i was configured the device as a thirt-party becouse the cucm 11.0 does not support the kit room mini.
05-10-2021 07:29 AM
05-10-2021 07:24 AM
Do you have all the settings configured as per below guide including Directory Number?
05-10-2021 08:17 AM
Thank you,
yes exactly i did the same steps but it doesn't work.
05-10-2021 08:56 AM
05-11-2021 02:41 AM
