Clean Phone Handsets
David Undernehr
Wanted to poll the audience and see what solvents you are using to clean phone handsets if a user spills soda on it.
Its still functional (at this time) other than a sticky hook but was just courious if you have come up with a perfect solution.
Thanks in advance!!!!
5 Replies 5
paolo bevilacqua
You can open the phone and clean it inside.
There is no good way to clean sticky keys from outside.
Dennis Mink
WD40
Please remember to rate useful posts, by clicking on the stars below.
minkdennis wrote:
WD40
I disagree. No lubrication or protective coating is needed on phones.
David Undernehr
Thanks for the replies....I think good ole alcohol did the trick for now.
You're welcome, please remember to rate useful posts clicking on the stars below.
