11-28-2016 02:07 AM - edited 03-18-2019 06:38 AM
Hi all,
I'm using TMS version 14.6. I'm trying to configure CMR Hybrid user in TMS. When i enter Webex username & password then i click Save, it shows error message : "Cannot connect to the WebEx site". I'm sure that webex site,webex username, and webex password is correct cause i can login using web browser to webex site URL.
Does anybody have any idea?
Thanks.
11-28-2016 08:56 AM
Has your WebEx site been provisioned to support CMR Hyrbid?
CMR Hyrbid requires a Cisco partner to perform the installation, this is outlined in the "Ordering and Deploying CMR Hybrid" section of the CMR Hyrbid Release Notes for TMS 14.6.
12-06-2016 07:40 PM
Hi Patrick,
Thank you for your info.
