11-06-2018 06:09 PM - edited 03-18-2019 02:26 PM
Is the Call Capacity of CMS 1000 M5 the same as M4?
In the data sheet, M4 information is written.
https://www.cisco.com/c/en/us/products/collateral/conferencing/meeting-server/datasheet-c78-737519.html
Full HD 48
HD 96
SD 192
Audio 3000
CPU Clock has been increased from 2.1 GHz to 2.3 GHz.
Does the call capacity go up?
11-06-2018 06:42 PM
Documentation, either the data sheet, and/or the CMS docs, should be updated with the capacity for the M5, you can reach out to your SE in the meantime to try to get this information.
11-06-2018 08:54 PM
Wait for updating the datasheet.
I'd like to check it soon, so I will ask the Cisco AM about the call capacity of the CMS 1000 M5.
P.S
I changed the title of the discussion.
11-06-2018 11:09 PM - edited 11-06-2018 11:11 PM
I found that CMS 1000 M 4 and CMS 1000 M 5 have the same call capacity.
Datasheet is writing about M4.
M4 and M5 have the same call capacity, but wait for the description about M5.
Jaime.
Thank you for your comment.
11-25-2021 07:14 AM
Dear Members,
What is the difference between M5 and M5 V2 server. Does it required hardware replacement to move from M5 to M5 V2.
Malik
