Walkthrough Wednesdays
666
Tien Phuong
Beginner
CMS 2.4.1 WebRTC via Expressway problem
Hi all,
My system deployment webRTC via expressway.
- CMS: 2.2.9, Expressway C,E: X8.9.2
Everything is ok.
But when i upgrade CMS to lastest version (2.4.1), i can not use webRTC via expressway. Web browser not sent't anything.
I not find any log about error on CMS and expressway.
Anyone can help?
Attach file is browser screen when i login to webrtc via internet
6 REPLIES 6
timspiller
Beginner
What version of Google Chrome are you using?
I am using lastest version of Chrome. Beside, i tested with another browser and have same issue.
Clear your Browser Cache .... faced same thing after doing the upgrade ..
Also , try to test internally to isolate internet problems ..
zeuscyril
Enthusiast
hi tien,
have you checked compactability between cms 2.4.1 and expressway ?
https://www.cisco.com/c/dam/en/us/td/docs/conferencing/ciscoMeetingServer/Release_Notes/Version-2-4/Cisco-Meeting-Server-Release-Notes-2-4-1.pdf
check in this 8.9 version not supported part.
Hi zeuscyril,
I have tried to upgrade exp to lastest version (X8.11.4) but still happend same issue? Do i need upgrade CMS2.2.9 to CMS2.3 firstly?
----Update---
I have tried login webRTC with URI: https://join.xxx.com.xx --> Not OK.
But when i tried URI: https://join.xxx.com.xx/index.html?lang=en-US --> OK
Content for Community-Ad
Spotlight Awards 2021
