Walkthrough Wednesdays
271
Tien Phuong
Beginner
CMS and LDAP problem
Hi all,
I have system with 6 CMS server. When i login to webRTC or CMA, have error: "username/password incorrect".
I sync LDAP successful, xmpp, check SRV is ok
I check webGUI have error as attach file.
Any one have an idea?
2 REPLIES 2
Oleksandr Yurchenko
Enthusiast
I don't see "ldap sync operation complete" in your log messages .
Check LDAP connections first.
br Oleksandr
Thank Oleksandr for your reply,
i'm sure that LDAP sync ok, user synced to CMS.
CMS and LDAP server is in the same subnet so i think don't have any problem about connection.
Before that, when i configure priority and weight of SRV record similar with all CMS, i can login normally.
But after i change priority and weight of SRV record to other values, it happend problem.
Do you have any idea?
Content for Community-Ad
Spotlight Awards 2021
