03-01-2018 07:09 AM - edited 03-18-2019 01:55 PM
We installed cm 11.5, cms 2.3.1.
I also installed SX80, DX70 and SX10 terminals.
DNS installation and AD installation are not done, only CUCM and CMS trunk are interlocked.
However, dual screen function does not work.
I am wondering if it supports only ad-hoc.
Or I wonder if other settings are needed.
03-01-2018 01:18 PM
Only the SX80 supports multiple screens (if you have it setup that way) - what SW version are you running on it? The Dual Stream CMS feature will not affect the behavior of single screen systems like SX10 and DX's.
03-01-2018 07:11 PM
The version of all terminals is ce 9.2.3.
The cms version is also 2.3.1.
After the CUCM trunk configuration, I am going to have a meeting with a rendezvous.
However, it does not support dual screens. Only one screen comes out.
When capturing with a wire shark, the CMS sends only one video and audio stream to the terminal.
Do you have any problems with other settings?
03-04-2018 09:20 PM
03-09-2018 09:41 PM
Thank you.
Resolved with API through Postman.
Dual screen comes out well.
