12-17-2019 08:50 AM
IT doesn't work. Which other steps are we missing?
Thanks.
12-17-2019 01:04 PM
Have you changed the meeting type in TMS from One Button to Push (the default) to automatic connect? Then also consider that unless you change the devices to auto answer, they will not connect unless someone is there to answer.
12-17-2019 09:11 PM
Have you booked the meetings with automatic connect on TMS or OBTP?
Also whether the auto answer mode is on on endpoints?
If that is there can you collect the CMS sip debugs to see if the calls are being routed to CUCM or not?
If it is routed to CUCM what is the error with which CUCM is rejecting the calls?
One more thing have you applied inbound CSS on CMS trunk so that it can reach to endpoints?
Please rate if it is helpful and mark as accepted solution if applicable.....
01-22-2020 08:18 AM
Thank you very much¡
It finally works although we are facing an unexpected behaviour since the call is inmediartly answered after a slight beep. I have tried to modify the "Auto Answer delay" service parameter without success. Moreover, all the calls are connected, is there a way to differentiate among types of calls?
Thansk again
01-22-2020 09:03 PM
Hello
What do you mean by differentiate among types of calls?
Can you please explain a little bit more
