CMS Recording - Automatic and On-Demand Simultaneously
bejoy.cisco
HI,
we are having a CMS and CMS recording set up.
As of now, CMS recording is set for manual recording, the user can start and stop the recording with a digit string.
This applies for all the spaces.
We have a new requirement that we need to have 2 spaces on always recording and other spaces on-demand recording.
Is this possible, if yes, how to configure?
Bejoy
Hello Bejoy,
You can take a reference from below link-
https://www.cisco.com/c/en/us/support/docs/conferencing/meeting-server/202722-Configure-Recorder-in-CMS-Acano-Call-Bri.html
In this all the profiles has been set on system level, but you can do it on cospace as well.
For more details please refer the API guide-
https://www.cisco.com/c/dam/en/us/td/docs/conferencing/ciscoMeetingServer/Reference_Guides/Version-2-3/Cisco-Meeting-Server-API-Reference-Guide-2-3.pdf
Please rate if it is helpful...
5 Replies 5
Jaime Valencia
Create a Call Profile with recording set to automatic and assign to those spaces.
java
if this helps, please rate
Hi Java,
Thanks for the reply, can you please share any docs on how to do this.
Hello Bejoy,
Hi Anurag,
Thanks for sharing the guide, that was helpful. Got the individual cospace to record automatically.
Also.. can you give a tip on how to restrict participants, other than the initiator, from starting Or stopping a recording using DTMF string in a space while a conference is going on?
Bejoy
Hello Bejoy,
I think we can do it through Host and Guest feature. But i need to try.
Please see the below link to enable Host and guest feature-
https://www.cisco.com/c/en/us/support/docs/conferencing/meeting-server/213552-configure-and-troubleshoot-guest-and-hos.html
