AMA-CUCM Troubleshooting: Best Practices for Reading Trace Files
453
Beginner
CMS streaming - invalid interface
Dear Colleagues,
During an CMS streaming configuration I have got an invalid interface error message.
>streamer listen a:445 lo:445 whitelist
Error: Invalid interface
I tried with different ports and interface with no success.
Have you faced one of you with this problem?
Laszlo
1 ACCEPTED SOLUTION
Highlighted
Beginner
Re: CMS streaming - invalid interface
As it turned out, there was a simple syntax error, I had to leave the whitelist term.
The proper command is:
Typical user error ;-)
3 REPLIES 3
You have it configured to listen on interface a as well as the loopback interface, it could be that the loopback interface uses interface a and is causing a conflict. Have you tried to use either interface a or the loopback interface, instead of both?
Beginner
Thanks for replying me.
Yes, I have tried to run the command with interface a and loopback separately and together as well... same error as I mentioned.
Highlighted
Beginner
Content for Community-Ad
August's Community Spotlight Awards
