12-28-2020 11:30 AM
Can someone send the link to download the web_branding.zip file that is for the CMS 2.9.2 ??
Thank you.
Solved! Go to Solution.
12-28-2020 04:27 PM
its available for download from below link.
12-29-2020 07:55 PM
The file name should be "sign_in_settings.json". your extension is showing as ".jason"
when you extract web_branding.zip file it should directly extract to files (not to a folder)
12-28-2020 04:27 PM
12-29-2020 09:43 AM
I see the code but still not changing the text below the logo in the web_branding.
Below is what I uploaded to the CMS but the text still isn't changing ...
I used Notepad ++ and saved the file as .jason
"browserTabLabel" : "USACE Meeting App",
"panelLabel" : "USACE Meeting App",
"allowClient" : "true",
"allowWebRTC" : "true"
Still show Cisco Meeting App under the logo. ???
Any ideas ??
12-29-2020 07:55 PM
12-29-2020 08:18 PM - edited 12-29-2020 08:21 PM
As @Sateesh Katukam mentioned make sure the name is sign_in_settings.json.
Make sure the ZIp files which you created are not in folder. I have attached one which i use.
09-27-2022 08:04 AM
hello,
i have the same probleme here bellow my files and jason file, i can upload all files and i see changing but not jason file wich doesn't work, i ve used your zip file for test but it doesn't work could you help
09-27-2022 09:24 AM
thanks, i found the solution for this issue .
