Dear all
Does somebody an idea how can I configure SNMP on the CMS2000 plattform?
I can't find the mmp command snmp .....
I see only the snmp command on the CMS1000 or virtual plattform .
any Input appreciated.
Best Regards
Georg
Solved! Go to Solution.
As per the Install Guide (See table in Differences in components enabled on the different platforms section), the CMS2000 does not currently support SNMP.
Hi Wayne
Thanks for the Feedback, ok is clear.
Best Regards
Georg
