03-08-2016 08:10 AM - edited 03-18-2019 05:40 AM
We have a conductor with two bridges in one pool,
bridge 1 : 8710 - 12 screen licenses
bridge 2 : MM820 - 30 screen licenses
I found that seems unable average allocation of resources.
When there are many meetings,that will appear
bridge 1 : 99%
bridge 2 : 45%
It seems evenly distributed in accordance with the number of meetings, not by currently resources.
Is that normal?
And how can I make it an average allocation of resources?
Thanks.
Solved! Go to Solution.
03-09-2016 08:48 AM
What software version is your Conductor?
You can can use the conference placement option introduced in Conductor XC4.1 that either selects the conference bridge with the most spare capacity or fewest conferences. The default is to use the conference bridge with the fewest conferences, refer to the Conductor XC4.1 Release Notes for more information.
03-08-2016 10:33 PM
What does Service profile configuration says in Conductor, what is priority assigned to pools.
thanks,
Amit
03-09-2016 08:48 AM
