Hi All
Having an issue with the syslog server setup in a clustered Conductor setup.
Running Version 2.3
When I remove the syslog server address from the master, it stops sending logs to the syslog server. (as expected)
(maintenance -> logging)
When I remove the syslog server address from the secondary it continues sending logs to the syslog server.
When I check the configuration it is not showing, yet the messages continue.
We are getting flooded with (several every minute):
conferencefactory.switchboard: level="INFO" Event="A management request has been received."Command="device.query" Requester_(VCS/Unified_CM/client)_
I have noticed in the primary when I change the syslog servers that in the event log is an entry:
management: Level="INFO" Detail="Updating syslogd configuration file" Filename="/tandberg/persistent/syslog-ng.conf"
However, this entry is not appearing in the secondary conductors event log when I edit the syslog servers, this makes me think the configuration file still has the address listed.
Is this a known bug?
I logged in as root user and I can see that /tandberg/persistent/syslog-ng.conf has not been changed from when it was first set.
Any help is greatly appreciated.
