01-14-2016 01:41 AM - edited 03-18-2019 05:25 AM
I'm having problems with controlling conferences via TMS/Conference control center. The TMS booking is working fine, conferences are created via Conductor in MCU/TPS.
But when I go to the CCC I find these errors:
Date Type User System Description
14/01/16 10:17:55 ConferenceError SDS_CONDUCTOR No contact with master system, 3 successive polls failed.
14/01/16 10:17:55 PollMasterFailed SDS_CONDUCTOR No response from main system
14/01/16 10:05:21 ConferenceError SDS_CONDUCTOR No contact with master system, 3 successive polls failed.
14/01/16 10:05:21 PollMasterFailed SDS_CONDUCTOR No response from main system
14/01/16 9:52:48 ConferenceError SDS_CONDUCTOR No contact with master system, 3 successive polls failed.
14/01/16 9:52:48 PollMasterFailed SDS_CONDUCTOR No response from main system
14/01/16 9:40:15 ConferenceError SDS_CONDUCTOR No contact with master system, 3 successive polls failed.
14/01/16 9:40:15 PollMasterFailed SDS_CONDUCTOR No response from main system
14/01/16 9:27:41 ConferenceError SDS_CONDUCTOR No contact with master system, 3 successive polls failed.
14/01/16 9:27:41 PollMasterFailed SDS_CONDUCTOR No response from main system
14/01/16 9:15:08 ConferenceError SDS_CONDUCTOR No contact with master system, 3 successive polls failed.
14/01/16 9:15:08 PollMasterFailed SDS_CONDUCTOR No response from main system
14/01/16 9:02:35 ConferenceError SDS_CONDUCTOR No contact with master system, 3 successive polls failed.
14/01/16 9:02:35 PollMasterFailed SDS_CONDUCTOR No response from main system
14/01/16 8:51:32 ConferenceError SDS_CONDUCTOR No contact with master system, 3 successive polls failed.
14/01/16 8:51:02 PollMasterFailed SDS_CONDUCTOR No response from main system
14/01/16 8:50:32 PollMasterFailed SDS_CONDUCTOR No response from main system
14/01/16 8:50:00 ConferenceError Automatic MCU failover not possible. No valid route found.
14/01/16 8:50:00 ConferenceError SDS_CONDUCTOR Allocate failed, conference is not automatically connected
14/01/16 8:50:00 ConnectCallWarning SDS_CONDUCTOR Allocation failed: Description: {"status":"error","info":"conference already present: conference_name 'Sala'","factoryConferenceId":"4d6532686758ee937c862d21883f5acec959f412")
14/01/16 8:50:00 ConferenceInfo Non-secure conference. Original value of the setting was 'if possible' and not all participants support encryption.
14/01/16 8:50:00 ConnectCallWarning SDS_CONDUCTOR Allocation failed: Description: {"status":"error","info":"conference already present)
14/01/16 8:50:00 ConnectCallWarning SDS_CONDUCTOR Allocation failed: Guid should contain 32 digits with 4 dashes (xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx).
14/01/16 8:50:00 ConferenceActive Conference started
14/01/16 8:49:00 CallInfo Display 1 minute message
14/01/16 8:45:00 CallInfo Display 4 minute message
13/01/16 11:45:49 ConferenceInfo Operaciones Conference end time changed from 01/14/2016 15:15:00 +01:00 to 01/14/2016 13:15:00 +01:00
13/01/16 9:27:13 ConferenceInfo Operaciones Conference created
In the Navigator/Conductor tab I found this:
Incorrect Management Address.
If I try to Enforce Management Settings does nothing. If I try to add a IP manually, nothing too.
Any sugestion how to make CCC works properlly?
Thx in advance,
David.
01-14-2016 07:37 AM
Duplicate post.
